Flash to iPod, Swf to iPod video converter Guide for Windows
If you'd like to convert DVD, AVI, MPEG, WMV, RM, MOV, ASF, RMVB, DIVX, XVID, VOB, etc. to
iPod video, have a look at
http://forums.afterdawn.com/thread_view.cfm/297023
How to convert Flash swf movie files to iPod video using Flash to iPod Converter and
transfer to 5-gen video iPod.
1. Download flash to iPod Converter from
http://www.allforvideo.com/download/Fla ... p_v110.exe , intall and
run.
2. Click "Add Flash", load your Flash (.swf) movie or video files.
Tips: You can play the swf file by clicking "Play" button.
3. Click "Convert Now!" to start converting swf flash to iPod mp4 video format.
Tips: (optional) Before converting, you might as well set "Output folder" to somewhere you
like.
Trouble Shooting: No audio or the audio is low
If you play the iPod video files you converted and find that audio is a little bit lower or
there is no audio at all, please check your Volume control for your audio device and select
"Stereo Mix" or "Wave out Mix" as the recording source in the Recording Control window, and
then reconvert.
a) Right Click the "Volume" button in the taskbar, choose "Adjust Audio Properties".
b) Go to "Audio" tab, click "Volume" from "Sound Recording" area.
c) Select "Wave out Mix" or "Stereo Mix".
4. Drag .mp4 files that the swf flash to iPod converter created into your iTunes library,
and then transfer the iPod video files to your 5-gen iPod by clicking 'File -> Update
iPod'.
Just so easy to convert swf movie to iPod. Enjoy!
